Start with the speakers. They,more than anything else, will determine how good everything sounds. Since you have a large space try to pick high effiencey speakers. I would keep the 702 until last, it is not a bad receiver.
Originally Posted by cjhmcox I recently built a home and they were offering "home theatre" built in. I went for it. Bad idea! With the purchase I received: 4 Proficient brand in-ceiling speakers 1 JBL PB 10 Subwoofer and 1 Onkyo TX-SR702 receiver I had to add a center channel - which is a Klipsch Synergy This is all in a rather large room (16' x 20' w/ 10ft ceilings) - no vaulted ceilings- but rear opens up to the kitchen. The problem that I have is I have absolutely terrible sound. I have tried Jurrasic Park, UB571, Top Gun...and none of them have any power or dramatic feel behind them. I'm going to overhaul the system, but wonder where to start. Receiver, book shelf speakers with matching center, new sub. All help appreciated. Monitor Audio R90 with R180 seem nice from the posts along with a HSU VTF-3 MK2. Thanks |
Originally Posted by cjhmcox Looking at Monitor Audio bookshelves...what line is better Bronze or Radius. They don't seem to be that "efficient" but all the reviews seem very good. Klipsch have 95db sensitivity buy everyone says the horn tweeter makes them sound poor. |
Originally Posted by CEGUY Before you spend any money, check your room acoustics. Walk around the room and clap your hands very loud. If you hear a distinct and prolonged echo(or series of echoes), you have a live room and nothing you can do with hardware is going to change that sound. If you hear the echoes you might want to try to damp the room with curtains, tapestries, rugs, etc. That will work wonders for your system For the low end, you might want to try moving the sub. Also make sure that the crossover in the sub is set to either the highest frequency or better-"bypass" Make sure your speakers are set to ""small in the Onkyo. |
Originally Posted by cjhmcox i think it was around 2k with all the wiring and speakers. I'm leaning toward small bookshelf speakers with matching center for the front and keeping the rear ceiling. what do you suggest for the mains that are small. Think i'm going to go with hsu sub 12". |
Originally Posted by einsteinjb Buddy, saying that you're thinking of going with "small bookshelf speakers" and asking for suggestions is like saying you're thinking of buying a small car and asking for suggestions. Bit wide open, that is. Actually it would be easier to guide you towards buying a small car than small speakers! What's your budget for the front 3 speakers? What are your listening habits? What percentage music/movies do you listen to? What brands and models have you listened to and liked or didn't like? Do you prefer a full, warm sound, a bright/detailed sound, a very neutral sound, etc.? And what are your aesthetic needs or preferences? Meaning do you have to have wood grain, beautiful finishes, etc. or is plain black perfectly ok? The more info you give the better suggestions you'll get. (But of course going out and LISTENING is the best suggestion.) You'll love the Hsu subs, they're wonderful. |
