TH-42PD25U/P aspect ratio issues
290 Views 0 Replies 1 Participant Last post by  Jacuzzi
When I watch a channel broadcasting 480i, the aspect ratio is only correct in "just". 4:3, zoom and full all are shown in the 4:3 area with vertical black bars within the 4:3 area and are shown with washed out color but correct picture. (zoom is still zoomed, you just only see the portion of the picture visible in the 4:3 area, between the black bars that are also within the 4:3 area.)
PIP works fine.
Aspect ratio Just works fine.
I am using an OTA antenna only.
I have had the TV for about a month. I used to be able to use all the aspects for a 480i signal. Although, I have been using "just" exclusively for the last 3 weeks or so. I have not made any changes other than using cinema. I'm perplexed, why would one aspect ratio work/look fine and the other 3 not?
:confused:
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
