Sunday was filled with cleaning up the basement some more and to begin wiring up the light switches in the theater room along with the rest of the basement. Had to remember some of what I did from last year with 3/4way circuits which is always fun.
Installed in the theater room 6 Lutron Casetta Wirelless Switches and plan to install the smart hub later to control everything from our phones/tablets/etc. I prewired and tested the circuit to make sure everything worked before I installed the gang extenders and finished the installation.
Semi final pic below. I decided to pic white just so they would stand out in the dark for the kids and its in the back of the room behind the seats. The wall plate would not fit so I will go back later and bend the wire to adjust the switches before finishing. I used the two extra gangs to install some Legrand night lights that are activated by touch. I need to call customer support though because they turn off on there own which I figured would happen. The Caseta Wireless switches group the neutral wires together to monitor the state of the lights and the night lights need to use the neutral wire connected directly to the light. I am assuming that the Casetta switches are telling the lights to randomly turn off. The 6 switches control the lights as follows:
- Back Wall Lights
- Both Side Wall Lights
- Screen Wash and Behind the AT Screen Lights
- Ceiling Flushmount LED's
- Tray Ceiling Outlets (Plan to install either LED Rop Lights, Black Lights, or LED Star Ceiling). The wife and kids think it would be cool to paint the ceiling but I kind of like the LED Star ceiling.
- Riser lights and step light
