here's the true story of someone who was accidentally exposed to total vacuum as part of a NASA test...So this was the episode that threw all the science away? I was even more annoyed by the last 5 minutes. Just no.
So Cyn should have had another 11 seconds before unconsciousness.here's the true story of someone who was accidentally exposed to total vacuum as part of a NASA test...
The Time a NASA Experiment Gone Wrong Almost Killed Someone
In a giant chamber with no air, all sorts of bad things can happen.www.popularmechanics.com
What science are you referring to? Your movie experience science where people blow up of freeze solid in space. I was in that corner but did some reading on it a while back. and although this is far fetched for sure it is plausible. SA Corey is a good follow on twitter and explains a lot of this stuff. They try to base things on real science.So this was the episode that threw all the science away? I was annoyed with the yacht and Inaros' ship suddenly having gravity. I was even more annoyed by the last 5 minutes. Just no.
Sent using Tapatalk
Remembering the book details where this same thing happened. First, I think they made the distance and trip longer in the show. Second, they made a point that Naomi had figured this out and knew that she had to expel the breath in her lungs for this to work. Third, she won't escape unhurt.So Cyn should have had another 11 seconds before unconsciousness.
Naomi waited 37 seconds to take the injection, unknown how she prepped to last 37 seconds in a vacuum but conceivable given available tech, belter conditioning and a little planing (something she could have simply done on the way to the air lock).
69 seconds till Naomi experience atmosphere in the airlock.
Now why can't they just bring the ship back? Will Naomi be able to disable the remote nav?
You do freeze solid, but it takes along time. I forget the actual terms, but since there is no air there is no direct contact like freezing cold air or water. But as the belters say "Not be good outside ship, sa sa".What science are you referring to? Your movie experience science where people blow up of freeze solid in space. I was in your corner but did some reading on it a while back. and although this is far fetched for sure it is plausible. SA Corey is a good follow on twitter and explains a lot of this stuff. They try to base things on real science.
I always thought you died instantly if exposed to space but apparently not.
Maybe I hated The Last Jedi for no reason now that I know this...... na, it was still garbage.You do freeze solid, but it takes along time. I forget the actual terms, but since there is no air there is no direct contact like freezing cold air or water. But as the belters say "Not be good outside ship, sa sa".
That was a really fun watch!One of the most on-the-mark and funniest of the YouTuber/critics finally watches the series:
if Marco's plan was to kill Holden why didn't he just wait until Holden boarded the Zmeya and then detonate the explosives?...seemed like an easy kill...special shoutout to Brent Sexton who did a fantastic job playing Cyn...great job with the Belter dialect as well...
I don't think there was any remote destruct on the Zmeya. Also, we've already learned that Marco is in league with a significant faction on Mars. Marco has been using the PM as a threat to keep Earth from retaliating but Monica figured out that the PM plus the scientist (Cortazar) were probably the price for the warships. Marco probably no longer has the PM and it may be that it was just transferred in TT's posts above.I don't understand the question. I'm pretty sure Holden accidentally killed the Zmeya. If the Zmeya had a remote destruct Marco wouldn't have needed the Chetzemoka as a decoy. Also, "if I can't have it, no one can" isn't really an option for Marco. His possession of the PM is the only thing keeping the Free Navy from being obliterated by Mars, the UN and the OPA.
I didn't see it that way but you could be right...I thought the Rocinante only disabled the Zmeya's drive so it could be boarded...as far as the Chetzemoka, Marco always seems to have multiple back-up plans...the original plan for the Rocinante was to destroy it when it took off from Tycho Station with the malicious Augustin Gamarra code...so everything with the Zmeya and Chetzemoka was just Marco being resourceful and creating new plans when his original one didn't workI don't understand the question. I'm pretty sure Holden accidentally killed the Zmeya. If the Zmeya had a remote destruct Marco wouldn't have needed the Chetzemoka as a decoy. Also, "if I can't have it, no one can" isn't really an option for Marco. His possession of the PM is the only thing keeping the Free Navy from being obliterated by Mars, the UN and the OPA.
It's not an explosive in that sense. It 's the nuclear core itself. The "normal" computer program that controls the fusion starttup reaction was modified by Naomi. "if Marco's plan was to kill Holden why didn't he just wait until Holden boarded the Zmeya and then detonate the explosives?...seemed like an easy kill...special shoutout to Brent Sexton who did a fantastic job playing Cyn...great job with the Belter dialect as well...
are you saying that...the Augustin Gamarra code was activated on the Zmeya causing the explosion?It's not an explosive in that sense. It 's the nuclear core itself. The "normal" computer program that controls the fusion starttup reaction was modified by Naomi. "
