After watching some SD DVD, Blu-ray and HD DVD movies on the LG "combo" player I can say all-in-all I'm pleased with the purchase.
Pros:
1. It does play back SD DVD, Blu-ray and HD DVD movies.
2. The picture quality of Blu-ray and HD DVD looks similar although I must say MI:3 on HD DVD looked awesome. I have not seen a 1:1 comparison yet as I don't have the same movie in both formats (I'll wait for Total HD). SD DVD looks good for SD. I went from 480p component to 1080i HDMI so that alone was an improvement. Mostly the black levels of the LG on SD DVD was better than my older (expensive at the time) SD DVD player.
3. Sound quality was okay. I listened to DTS and DD 5.1 via SPDIF.
4. Blu-ray and SD DVD menus work just fine.
5. Remote was easy to use but I learned the buttons into my Pronto and put the remote away.
6. Power up speed seemed fine as I have not used any other Blu-ray or HD DVD player. The time to play a disc also seemed fine although it is longer then my old SD DVD player. Menus are fast and response time for fast forward, rewind, pause etc. on Blu-ray and HD DVD is fast.
7. Buttons on top of the unit are cool. Yes they might be in an odd place for some but I like putting a disc in the tray and "touching" the eject button just above the tray. The buttons are touch sensitive so you don't have to push them. And they light up and beep as you glide a finger across them. Setup time was easy as the setup menu was relatively simple and was easy to use.
8. Front panel display is informative and easy to read (from close up). From far away it's easy to see the time and play mode.
9. 1080p was output but my plasma only handles 720p. Actually 1080i looked better especially the menus.
10. I did not have a lock up or skip with the movies I watched.
Cons:
1. High price but considering it's mainly a Blu-ray player it's not that much more to also be able to spin an HD DVD disc. I don't have room in my equipment cabinet for two players and I don't want to use two HDMI connectors just to be able to play both formats so it's a good compromise for me. Plus I lean towards Blu-ray anyway so I can now buy/rent Blu-ray movies and still play exclusive HD DVDs.
2. Non-existent HD DVD disc menus. The custom HD DVD menu is usable but not very friendly. If you can find bonus material you can still play it but since you have no idea what the bonus material is it's more of a "play each title/scene and see what it is". I'm not much of a bonus material person anyway so this does not bother me. I just want to watch the movie.
3. Lame support for newer audio codec's. True HD and DTS-HD output as 2 channel PCM over SPDIF. DTS and DD 5.1 worked fine.
4. LAN port has signals present but is not mentioned in the menus and the manual says it's only a "service port".
5. Does not play CDs.
Conclusion: "B+" and if a firmware update improves the audio output (True HD and DTS-HD) then "A". I'm glad to finally be able to watch HD movies and I think the format war was a dumb idea - didn't we learn anything from Beta vs. VHS and DVD+R vs. DVD-R? I will buy/rent Blu-ray discs and if a movie is only offered on HD DVD then I am covered.
Pros:
Cons:
