Originally Posted by tshepp /t/179095/the-official-avs-hdtv-stb-synopsis#post_23060863
I am still looking as well...Just got my 8350 and need an HD tuner to pick up the local HD channels.
Originally Posted by ExigeS /t/179095/the-official-avs-hdtv-stb-synopsis#post_24012384
Can anyone recommend a QAM tuner that will work with Verizon FIOS in Maryland? I have one old TV without a internal QAM tuner and I want to get some channels on it without having to pay a monthly charge for a FIOS digital tuner. I have a new tv with an internal QAM tuner and I am able to get many channels including HD by only hooking the coax directly to it and I am looking to do the same on the older TV. I see several makes and model QAM tuners on the market but I am looking for some insight into what will work before I buy. Any assistance would be appreciated.
Originally Posted by navychop /t/179095/the-official-avs-hdtv-stb-synopsis#post_24012957
I'm checking on what, if anything, can be gotten without a cablecard. Or would you be willing to pay the cablecard fee? I assume no cablecards in those TVs?
Actually, I doubt this is a good solution for you, but it's a challenge I wish to pursue.
Originally Posted by ExigeS /t/179095/the-official-avs-hdtv-stb-synopsis#post_24015172
It will not take a cable card, it's too old. I am looking for a solution that does not cost me a monthly fee. Thanks for looking into it![]()
And I don't mind paying for this requested device, but I want something that does not require a subscription. Defeats the purpose of what Im trying to replace! DVR is not important, but not a deal breaker.Ok, I could use some help/expertise here. I currently have a home theater with a projector, etc. I have Time Warner Cable, and use one of their HD STBs to watch tv on the projector (rarely). I'm currently trying to cut back on my TWC bill. Going to get rid of the box, and telephone, and just go with straight basic cable and internet. But, if I do that, then I have NO way to watch TV on the projector. I just bought a Vizio TV to use in my kitchen, it tunes in everything that I'd like to be able to watch. NTSC/ATSC/Clear QAM. What STB has anyone had good luck with hooking up to cable, having HDMI output, and being able to tune in all those options? Thank you to EVERYONE for your help!![]()
It's doubtful TWC has any clear QAM left. If they do, a $35 iView STB3500 will work. If they don't, you must have a cable card device, of which you have two subscription-free options: Samsung cable card tuner (~$130) or PC based tuner ($80-$200 depending on number of tuners). Last time I checked, a cable card from TWC ran about $2. So dropping a box saves you about $8/month. That means you'd break even on the Samsung in about a year and a half. PC based option is cheaper and gives you tons more features plus DVR and free guide. I've been doing that for years with great success. Works with a regular remote, so to the end user it works just like a cable box.And I don't mind paying for this requested device, but I want something that does not require a subscription. Defeats the purpose of what Im trying to replace! DVR is not important, but not a deal breaker.
I am on Time Warner cable in Nebraska and we still have analog and clear QAM. I have no idea how long that will last but I have had no notification and Time Warner will not say. For what it is worth my local office is very good. I have used cable cards and changed boxes and have had no issues. Very prompt when I have had a concern.It's doubtful TWC has any clear QAM left. If they do, a $35 iView STB3500 will work. If they don't, you must have a cable card device, of which you have two subscription-free options: Samsung cable card tuner (~$130) or PC based tuner ($80-$200 depending on number of tuners). Last time I checked, a cable card from TWC ran about $2. So dropping a box saves you about $8/month. That means you'd break even on the Samsung in about a year and a half. PC based option is cheaper and gives you tons more features plus DVR and free guide. I've been doing that for years with great success. Works with a regular remote, so to the end user it works just like a cable box.
Technically, Tivo with lifetime is also subscription-free and will run you about $300 for a decent used older model, $600+ for a new one. Really long payback time going that route, 3 years plus, but the easiest solution.
If you're willing to cut back to basic cable, would you be satisfied with just OTA instead, assuming you get good reception in your area?
Unfortunately, I do not get good reception in my area. I'm about 30 miles from the largest city, which has maybe 2-3 stations that broadcast, and 1 of which is a religious channel. The next closest is over 60 miles in multiple directions. I guess I've never tried a good antenna for HD reception. I do have an antenna in the attic that picks up radio for me. Might give that a shot and see what it picks up.It's doubtful TWC has any clear QAM left. If they do, a $35 iView STB3500 will work. If they don't, you must have a cable card device, of which you have two subscription-free options: Samsung cable card tuner (~$130) or PC based tuner ($80-$200 depending on number of tuners). Last time I checked, a cable card from TWC ran about $2. So dropping a box saves you about $8/month. That means you'd break even on the Samsung in about a year and a half. PC based option is cheaper and gives you tons more features plus DVR and free guide. I've been doing that for years with great success. Works with a regular remote, so to the end user it works just like a cable box.
