2701 - 2720 of 2739 Posts
Semi-Advanced Member
Thanks for your reply. Well given that I'm in a small apartment and a single SVS SB12 with barely any response down to 20 Hz, not that I can really make full use of that given the circumstances, I assume a single Crowson is going blow my mind based on what I've read here.
I assume the Crowson effect will be isolated to the couch only and the ULF won't affect by neighbors - I ask, it's probably a stupid question but in my complex I have very strict rules and I have an old lady living next to me. :rolleyes: Just want to make sure I'm safe in that regard.
Sounds like a perfect use for Crowsons to me - there is zero impact on your neighbors, while your couch is exploding.
I'd get 2 for the couch. As for amps, the NX amps are a lot cheaper, but if not in a different room (my Crowson amp is in the same room as the screen) they have very loud fans. After purchase, I discovered there is a "fan mod" that involves opening up the amp and making some changes - so I returned it and bought the (totally silent) D501. If you are good with opening up amps and making changes (and don't care about the warranty,) the NX amps can be an option.
I had Crowsons for a long time before I got a mini-DSP, and loved them. It's true that the mini-DSP (and a calibration by CallingMrBenzo and aron7awol) made the experience better, but if it were a choice of nothing or Crowsons without a mini-DSP, I'd still get the Crowsons.
After all, you can always upgrade/make the experience better, later.
I personally feel that the Crowson amp is much better as it digs down to 5 Hz and lower with the roll off, the Behringer goes down to about 20 Hz
Look, the D-501 has multiple benefits that you can highlight, but I've seen you post this multiple times in here, and I think we need to be careful to post accurate information. The behringers absolutely do not "go down" to 20hz. Have you seen their actual FR? And in any case, do you realize you can change a FR with EQ?
Like I said, the D-501 has some compelling reasons to buy it, including the fan noise. All of that is perfectly valid, I'm not even saying I recommend someone go with a Behringer over the D-501. So forget all that stuff when trying to justify your unrelated claims, it's irrelevant.
The reason for my post is that you saying it has a "frequency response" of 20-20kHz, and I'm not sure you actually know what that means. Do you think it means it is perfectly flat in that range and then has a brickwall below? Do you think it means that 20Hz is its -3dB point? What do you think it means? Now answer the same questions for the D-501.
The problem I have is you are making a claim that the D-501 "digs down to 5 Hz and lower with the roll off" and the Behringer "goes down to about 20 Hz", comparing them directly with those two statements which are so far from an apples-to-apples comparison, that it's, to be frank, useless.
It's important that when we give each other advice, that it's accurate. So I'm sorry that I'm kind of calling you out on this, but I feel like I have to prevent the spread of misinformation. I hope that you will be open-minded to this.
20hz to 20khz is just a standard range that many manufacturers use. This does not convey that a certain product will stop doing anything above or below this range.
  • Like
Reactions: CallingMrBenzo
Premium Member
I have a Behringer NX3000 and I can tell you it absolutely goes below 20hz.
Sent from my iPhone using Tapatalk Pro
Not really taking a side here, but it would be fair to assume (especially given the poor documentation behringer provides) that a 20-20khz response means the amp has a high pass filter centered at 20Hz and output below that will be attenuated to some degree which is exactly what we don't want for crowsons. Dayton Audios plate amps do this, although they clearly specify that on their website. While it's true that the rating doesn't mean the amp will misbehave outside of that frequency range there is no guarantee it will behave (have behringer amps been measured to deliver full power outside of the specified range?)
I mean surely there is a reason behringer lists the FR that way and doesn't let you EQ below 20 without using a high shelf filter?
  • Like
Reactions: H Stevens
Premium Member
The "Official" Crowson Tactile Motion Actuators Thread.
Would be curious to see some of that same data for the Crowson amp...
I mean -3db at 6hz is not bad at all... that’s pretty damn easy to account for...
The good thing is, we don't have to make such assumptions. :) They are a known commodity, not only can you see the FR was tested in the graph above, but the clean power output has also been tested, as has the zero-attack limiter.
Now, I think it's important to reiterate, I never said one amp was better than other, nor did I say one dug to X and the other dug to Y. The whole issue I had with that initial post was that saying one amp "digs to 5Hz" and the other "goes to 20Hz" was simply misinformation. There's very good reason that FR are shown as graphs, they can't be described by a single number.
I'm not trying to convince anyone to buy one amp or the other. They each have their pros and cons, and potential ways to mitigate the cons, if desired. The important thing is that people are using accurate information to make their decisions.
FWIW, I've published filters that can be entered in the NU/NX DSP itself to flatten the response, or for those with mDSPs, a filter that does it even slightly better.
Before looking at this thread I was thinking of upgrading my subwoofer (SVS SB12 NSD ) to a Power Sound Audio S1512. Now I think that would have been a pretty big upgrade, but what's the point in upgrading to a bigger sub if you can get tactile sensation down to 5 Hz or below?
What are the pro's to upgrading to a bigger sub if I'm getting a Crowson?
Premium Member
A single sub is never going to be anywhere near the feel of a device like a Crowson. You would need multiple subs to achieve the SPL and response levels.
Think of it as augmenting your experience without having loud volume or a bunch of expensive subs to get down to 10hz.
My sealed subs roll off at 25hz, so the Crowson really helps with all the down low stuff that you can’t necessarily hear but can feel.
  • Like
Reactions: MOberhardt
You cannot achieve what Crowsons can do with subs, having said that you should have a strong sub response in the audible range paired with a TR device. I would still think going from a 12 inch sealed SVS to 15' PSA would be a huge upgrade. Adding TR would be icing on the cake.
Premium Member
Agreed!
I just wish my other 3 would fricken show up!
I’ve also had pretty much all the other MA’s, Crowsons are where it’s at...
Agreed!
Well a Hover Boss is excellent but is a DIY solution. I’m putting a UM-18 in mine this weekend.
  • Like
Reactions: chrisnack
Yeah you will never get the same effect from subs as you'll get from Crowsons. Even if you do spend thousands and thousands on more powerful subs, and do then get the shaking effect, the level of sound at higher levels would be so high to get the equivalent tactical response that it'd be to my opinion way too many decibels in the audible range.
Got my nx3000 today. But now I see that nx3000 requires different cables which I don't have. Ordered XLR to rca for input.
But what cable should I use for the output?
Per the manual I have to use professional speaker cables with twist locking plugs. Where can I buy those? And what do you guys recommend?
Premium Member
They are called Speakon connectors.
This is what i got. https://www.amazon.com/gp/product/B07CRY3LH3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  • Like
Reactions: jbnpaul
Got a recommendation for some Crowson's over on the PSA sub page. Completely new to transducers. Look forward to reading through this thread
  • Like
Reactions: ht guy and Alan P
