I knew this was a classic amp by Carver and looked up the specs. This should be a very good start. The amp can go down to 2 ohm based on what I read. The main spec I look at if amp can drive Maggies is the power rating from 8 to 4 ohm. Amp also has cool needles so you can see them danceI have a Carver M500t that I bought as a kid and still have. It was recently refreshed at Hi-Tech Audio. I'm hoping it's a good start or I will be looking for an alternative at some point.
I‘ve been searching for another but no luck. I’m picky when it comes to cosmetics. The one I have now I replaced the faceplate because it had a small nick. There’s a great Ebay‘er selling newly milled faceplates that are fantastic. It’s not cheap getting it worked on so I’m hoping to get lucky to find one without breaking the bank so I can send it out to be worked on. And the meters are my favorite part. LOL!I knew this was a classic amp by Carver and looked up the specs. This should be a very good start. The amp can go down to 2 ohm based on what I read. The main spec I look at if amp can drive Maggies is the power rating from 8 to 4 ohm. Amp also has cool needles so you can see them dance
Their full specs:The membrane material is UV-resistant, moderately heat-resistant, humidity independent, which ensures long-term operation. This membrane weighs much less than the membrane of speakers made with other technologies on the market. Thanks to the push-pull electrostatic operating principle, its efficiency is extraordinary. Properly tuned and attenuated construction guarantees low distortion of the radiated sound which provides the opportunity for perfect sound reproduction.
The panels are fixed with screws. The disadvantages of gluing are eliminated at all points where it can cause deterioration or even loss of sound quality and performance over time.
You forgot to mention how much my SVS SB3000 sub is loved there tooIn Magnepan (almost) news today. There are several pinko commie countries from the Soviet block era now producing loudspeakers. Some are actually surprisingly good. There is an Estonian company Estelon , then there are the low cost high quality speakers from the Lithuanian Audio Solutions , just to name a few. Nothing good ever came out of my old stomping ground Russia, though. There are a few good efforts, but nothing worth mentioning and definitely nothing that penetrated even the European market, let alone American market.
There is also this Hungarian company Popori. They make only one model, the WR1. They look like Magnepans, but operate more like Martin Logans minus the woofers. Interestingly enough, their frequency response is almost flat with only a -1dB at 25Hz and sensitivity of 90dB, which , if true, will outperform Maggies as far as bass response and possibly dynamics are concerned.
They are a bit different from Magnepans, which is reflected in their price.
Their full specs:
Price: 36,000 Euro
Frequency response: 25-30 000 Hz, 300 Hz to 10 kHz +/- 1 dB
Sensitivity: 90dB
Maximum sound pressure: 110 dB
Impedance: min. 4 Ohm max. 8 Ohm
THD: <0.1%
Weight: 49 kg
Panel dimensions: H=1750 mm W=540 mm L=36 mm
Full dimensions: H=1793 mm W=540 mm L=436 mm
View attachment 3076074 View attachment 3076075 View attachment 3076076 View attachment 3076077 View attachment 3076078 View attachment 3076079 View attachment 3076080 View attachment 3076081
I had been away from all of my stuff for seven or eight months while in the garage doing a mechanical refresh on a recently acquired collector car. I still listened, but only on the little garage system. It keeps me from throwing toolsand the neighbors can't hear me fart unless I'm really really good and ripe that day. So well worth it (to them).
Now that winter is here, back to the systems in the house and back to the LRSs. I still find them just as refreshing to listen to as they were before and still quite happy, given the cost. Nothing else that I know of remotely close to that price range that I'd rather have. For folks who have never owned dipoles before, there's an acclimation period as you probably discovered. Plus, the challenges of positioning.
Well, I meant the gear designed and made there. But you are right , they love EMotiva and SVS there. To them you couldn't do better.You forgot to mention how much my SVS SB3000 sub is loved there too
Активный сабвуфер SVS SB-3000
Американская SVS Sound изначально специализировалась на сабвуферах, и к настоящему времени стала признанным экспертом в этой области. Модель, которую ...www.salonav.com
Oh.. I almost forgot, they Love those Klipsch Horns tooWell, I meant the gear designed and made there. But you are right , they love EMotiva and SVS there. To them you couldn't do better.
You could just not use Dirac Live.I have a question about room correction and Magnepan speakers.
Do people here have experience with Dirac + Maggie speakers?
I recently got an Emotiva XMC-1 to play along with my old Magnepan 3.6r + CC3 + MC1. Although I have run Dirac only once on them, and maybe it needs tweaking....but my first impression was that Dirac made Maggies sound exactly like box speakers. All the Maggie magic was extinguished immediately. All the nice open sound stage and "they are in this room" feeling went away. I now can easily hear where the sound is coming from, the speakers. Otherwise the Maggies simply disappear. I can turn off Dirac and the imaging goes back to what I like.
Maybe Dirac (and for that matter all room correction) is designed for normal box speakers, so that is the sound what they are steering for.
Is there a solution?
I don't know.One of my Magnepan 1.7 has lost its mid-range performance, big time! What can I do?
So, here's the story:
I just bought my first Maggies, a pair of Magnepan MG 1.7
- Bought them used from a guy online and very far away from where I live (in Sweden) ...about 770 miles away.
...so I basically have no chance of returning them.
What do you guys think?
- The rest of my equipment was playing without problems on some old Jamo-speakers, so no real problems there.
- After unpacking and starting to play music on these planar speakers I thought the sound was great-ish... ...but ...the sound stage seems shifted to the left a bit.
- So I start moving them around, checking the "tweeter-jumper" and the "Midrange/Tweeter Fuse"
- Seems that voices, guitars and sounds like that are just a LOT more clear and present from the left speaker.
- Tried shifting the speakers left to right and it was obvious that now the singer or guitarist is sitting more to the right instead.
- I've tried inspecting the membrane with a flashlight but can not see any real differences from the good working speaker.
- No visual weird stuff going on with the caps in the crossover either from what I can see.
- It plays the lowest and highest frequencies but somewhere in the mid range there has to be a problem with something!
Could it be the crossover?
What should I try first?
Please help!![]()
The 1.7 is a three-way speaker so the midrange section is out on one speaker. What is your technical level and what tools for analysis do you have? Are you willing and/or able to disassemble the speaker?One of my Magnepan 1.7 has lost its mid-range performance, big time! What can I do? 😭
- Tried shifting the speakers left to right and it was obvious that now the singer or guitarist is sitting more to the right instead. 😳
Please help! 😧😵
Thank you so much @DonH50 ! 🤗The 1.7 is a three-way speaker so the midrange section is out on one speaker. What is your technical level and what tools for analysis do you have? Are you willingdisassemblemble the speaker?
It could be the crossover, panel conductor, or wiring (including the fuse) to that section.
Troubleshooting (depends upon your skill and test equipment):
You can compare results for the good and bad speaker for most of these tests.
- With modest/quiet levels put your ear close to the speaker and move across the panel to verify it is the midrange, tweeter, or both that are out.
- Swap or replace the fuse to make sure that is not the problem.
- Visually inspect the crossover for bad/open connections.
- Measure the resistance of the coils (inductors) to make sure they are not open. You can buy a cheap digital multimeter (DMM) for this. I have a $5 special I got a few years ago.
- Measure the resistance of the sections (+ to - connections) after the crossover to see if the panel has an open section.
- Use an LCR meter to check the inductor and capacitor values (a DMM may have a capacitor range).
- Send pink noise or swept signal source through the speaker inputs and measure the signal across the panel sections after the crossovers. You can use the noise source from your AVR or whatever, or download test tones from the 'net. Do NOT play these loudly or for long!
HTH - Don
I do not have a 1.7 but would second the previous suggestion to contact Magnepan.Thank you so much @DonH50 ! 🤗
I would say I have moderate technical level but my multimeter can't measure the caps ...but as you say, DMM:s are not expensive, so I will look into that if I don't solve the problem before I get there.
So for the first point, to listen across the membrane while playing low music ...I've tried this and it is really hard to define. ...is there a special part of the membrane that "plays" the midrange?
...it's kind of obvious that the tweeter is where the "wires" on the panel is more closely spaced, but low and mid, are they "placed" so that mid is in the middle of the speaker and low is on the opposite side from the tweeter maybe?![]()
Thanks again!I do not have a 1.7 but would second the previous suggestion to contact Magnepan.
That said, historically bass has been on one side, midrange in the middle, and treble (tweeter) on the other side of the panel, so I imagine the 1.7's are the same. If you have a source of pink noise (from your source or download a file from the Internet) you can use that, otherwise just play some music or whatever and listen across both panels. With head turned so your ear is facing the panel and just a few inches away (keep the volume down!) it should be fairly obvious which area(s) is(are) quiet. If it is just the midrange then you can narrow down your focus; if it is both mid and tweeter then it seems to me more likely to be something like a bad fuse or connection somewhere to the mid/tweeter crossover section than a bad panel (unless both mid and tweeter were taken out).
Could you make another picture of this zone with a larger zoom or better definition? ThanksSo, I found out why my midrange was quiet. ...the lead has been sheered off physically: 😳
Any ideas on how to repair this? Anyone?
Soldering seems a bit brutal...![]()
