Front Wide guidance Marantz SR7005 Heresy ii / Magneplanar MMG
I have a multi-part question. An answer to the first question might make the others moot.
I have a Marantz SR7005 powering two Klipsch Heresy II's and two Magneplanar MMG's (also a Klipsch SW and a Klipsch Center). The Heresy II's and the MMG's are front speakers. I'm not interested in surround sound. I'd like to be able to listen to both of the speakers in tandem, and also switch between hearing only the Klipsch or only the Magneplanar. I can not get any music to come out of the Front Wide or Front Height speaker outputs, but I can get music to come out of the Surround outputs. Sound does come out of the Front Wide and Front Height when I test channel levels. I don't understand this but it might not matter. First question...
1. If I use the Surround outputs instead of the Front Wide outputs, will the receiver send different information to the Surround outputs as it might to the Front Wide outputs or will the information be the same (so long as I am listening in MULTI-CHANNEL STEREO)?
2. What are some reasons I might not get sound out of the Front Wide speakers? They work during channel level tests, but do not
work when playing music (and TV for that matter with HDMI ARC)?
3. Is it an input mode issue? I essentially want to run a 4.1 with two Front (small) and two Front Wide (small) and one SW (no center channel for music, just for TV). Any help or suggestions are so greatly appreciated. I'm overwhelmed by the generosity on this forum. It's unreal.
