Hi
@Gerben Van Duyl, here's another one:
Even well-braced and internally dampened speakers will exhibit some cabinet vibrations, that can produce additional output, and consequently affect the way the speaker sound. Maybe not such an issue for a speaker weighing over 100 kg, but the smaller speakers like the P5's will probably be more prone to this phenomenon. In the old days, with less developed drivers, this was not necessarily considered a bad thing by some audiophiles as it could camouflage driver deficiencies (like harmonic distortions), and depending on the resonance frequencies even add some "nice warmth" to the sound. Nowadays, having high quality drivers like in the Procella's, cabinet resonance is probably something you want to prevent as much as possible.
Chapter 6 of Procella's Handbook recommends baffle wall installation behind a AT screen, as it improves the sound by eliminating:
1) frequency response dips caused by reflections off the back and side walls (RED.: The harmful SBIR effects);
2) sound reflected back through the screen and from the back wall behind the screen (RED.: By sound absorption by the baffle wall itself); and
3) diffraction from speaker cabinet edges (RED: By being flushed into the baffle wall).
The benefit that seems to be missing here, is the elimination of the aforementioned additional (unwanted) output caused by cabinet resonances.
My question is if targeting the reduction/ elimination of the effects of P5 cabinet resonances when you are NOT using a baffle wall, could be worthwhile. For example, you could place the speaker inside small box made of / and or lined inside with acoustical (vibration and/or sound absorbing) material, and mount that as a whole on the wall and ceiling (close enough to still benefit from boundary gain).
What do you think?
PS To be clear, I am not looking for possible ways to reduce or change the vibrations of the cabinet itself, and thereby changing the acoustic design of the speaker (e.g. by ridged clamping or putting heavy weight directly onto the cabinet). What I want is to reduce or eliminate the effect of the sound emanating from the cabinet in cases where the speakers are NOT part of a baffle wall.
