2521 - 2540 of 4090 Posts
This turning over of the material might have some real effect to it. I find that with my new 130 inches screen the weave seems to be less visible than my previous 109 inches. Seating distance is the same. I assembled the new screen by unrolling the material so the inside of the roll is the exposed surface. With my previous screen, I don't remember which was which, but it is possible it might have been reversed.
Originally Posted by deromax  /t/842769/the-official-seymourav-center-stage-screen-thread/2520#post_24324488
I sent an email to Chris he recommend the inside off the roll. That is the surface that would be exposed if using a retractable screen. Also that is the surface that is inspected for imperfections.
He'd confirmed as much earlier in the thread.
Just trying to help as I tried it about a month ago.
I ended up using the outside of the roll which was in pristine condition (when it arrived).
Back (on mine)
Front/image side
Originally Posted by brwsaw  /t/842769/the-official-seymourav-center-stage-screen-thread/2520#post_24329417
Back (on mine)
Front/image side
Are those at the same distance, lighting etc?
They look really different.
When you say "Back" do you mean "outside of roll"?
They were the same or close to the same distance.
When I hung the screen I hung it from the 8' end (sideways temporarily) and the roll was to the back of the room, what is now "back" would have been the inside of the roll.
Originally Posted by brwsaw  /t/842769/the-official-seymourav-center-stage-screen-thread/2520#post_24329570
Okay, what you are calling "back" is where you are supposed to project the image (inside of roll). Good to know.
So using the 'wrong' side really appears to be different and viable.
I'm dying to receive my sample and see it in person!
I'm jonesing to put it back up.
Someone correct me if I'm wrong but there is supposed to be no back or front to this material. Its usually the inside of the roll that was inspected for defects. Maybe Chris can chime in on this one.....again
Chris said that both sides have the same look and properties. He recommends using the inside but my outside looked slightly better so I used it instead.
Originally Posted by cw5billwade  /t/842769/the-official-seymourav-center-stage-screen-thread/2520#post_24332902
agreed Since no QA was done on outside of roll I just went with the inside with no regrets
from rear of theater 19' from screen
from primary seating position about 9'
from primary seating position about 9' 4x zoom
12 inches from screen
12 inches from screen 4x zoom
Thanks for posting this. Definitely helps give one a sense of perspective. I will try to post similar shots comparing this and similar materials.
Hi Folks. I wonder what the current name is for the Logitech Harmony codes for the Seymour AV screen. I bought and installed my screen four years ago and love it. But I'm updating my remote and don't see Seymour in Logitech's database. A search of this thread shows that a device by Electronic Solutions (ESI) or Somfy would do the trick. But what specific model would I input into the Logitech software? BTW, my vague memory of four years ago says that Somfy was what I used then.
Many thanks, Ken
PS And what's with Logitech taking over four years to update the database?
I found a cache of old emails between me and Chris. So I'll post some answers here for others' future reference.
First of all I suspect that Logitech has two databases, since Chris reports above that one can find an entry for "Seymour AV". But I can't find that. The two Harmony's I'm using are the 890 and 900, which I suspect use an old, unsupported data base. And new remotes us a new database that does have "Seymour AV" in it.
So, for the older remotes and older Seymour Av screens, codes can be found for two motor options, Somfy and Electronic Solutions. My screen uses codes that Harmony calls Electronic Solutions and ESI, with model number RP60AU.
And just to make things interesting, Logitech has coded "open" to correspond to "screen up" and "close" for "screen down".
Cheers, Ken
Originally Posted by brwsaw  /t/842769/the-official-seymourav-center-stage-screen-thread/2520#post_24331813
Well it's back up.
I think I found out why the side with the diagonal patten should be used.
I reinstalled the opposite side, the side I suggested, the side I used before and I'm noticing some patchy blur when the lines on the image are parallel to the walls or the floor. Not alot but enough to wonder what if...
Originally Posted by ellisr63  /t/842769/the-official-seymourav-center-stage-screen-thread/2520#post_24410132
Does the screen have the little writing on one side near the edge like the samples do so you know what side to use?
I never looked.
It's fine at 120", I'm thinking it must be something else.
Is it possible the dust on the lens is effecting the image at 150"?
I'll square it up (better) later today and see if this helps too.
Looking at these screens, likely going to do a 120" screen with seating at 12-14 feet back, do I need to get the black backing, what does the black backing achieve exactly, it is not clear from the website? Greatly appreciate the help.
Premium Member
Originally Posted by prayformojo  /t/842769/the-official-seymourav-center-stage-screen-thread/2530_10#post_24444192
The black backing helps to block reflections from anything shiny behind the screen. (Because it is acoustically transparent it is also partially visually transparent.)
Thanks for the quick reply, that helps, not sure I will have anything shiny back there, but I guess if you were using certain speakers they may have a metallic part that could show through.
