1. Your Speakers get fool frequency range at "Large" option. But Sub get only LFE signal in this case.Hi Guys,
I'm a new A2080 owner and have a couple of tweaks I'd like to employ but don't know how to nor can I find any instructions on how to do them. So, may as well ask the experts. Here goes:
1. My fronts are Mirage OMD-28's with a frequency response at the low end of 25HZ. YPAO appropriately set them to large and appears to set the rolloff at 40HZ. How do I defeat this filter and set the rolloff lower ?
2. When connecting my 2019 Nvidia Shield to the receiver via HDMI, I can't get the receiver to pass the signal when I turn on Dolby Vision. I get a pink screen with some small patterns. SO, I direct connected the shield to the TV and ARC the sound back to the receiver. Unfortunately it appears ARC only works with CEC turned on so when I want to switch away from watching content on the Shield, it shuts down the receiver. Is there a way to use ARC without CEC ?
I'm using Monoprice certified high speed cables so that's not the issue, especially since DV works fine when plugged directly into the TV (LG65B7A). Net of the issue is if I can get the receiver to pass DV, I wouldn't need ARC. Now that I'm using ARC, I need to be able to use ARC without it controlling my receiver powering on/off.
Suggestions based on your similar experiences are much appreciated.
2. Check HDMI signal settings, read TV and Shield manual.
