4261 - 4280 of 4306 Posts
Onkyo TX-SR705 v1.04
Sorry I missed this until now. The "all in one" update CD ISO for the xx5 devices can still be downloaded from my Google Drive
https://drive.google.com/file/d/0BwNupHRxGNjrZWE5YWM3NDEtMWUyYy00M2U2LWIwZWQtMjFlZjkxY2JiMzEw/view?usp=sharing
This is the same CD that I was sending out when I was running the dongle rental service for updating 805 receivers.
Jasonvr - I have a Onkyo TX-SR705 with v1.04 firmware
Can I use that All-in-One ISO file to burn a CD disc and play it thru my CD player to update my AVR without the dongle ?
According to the instruction document on the CD, it appears that that as long as your 705 has main firmware 1.02 or later, you can update without a jig/dongle (i.e. serial only)
Hello Dear Friends,
I have an Onkyo TX-NR905
My Firmware is 1.05
I tried to download form the links that were posted years ago on the forum the last firmware but it doesn't work
Could someone send me a link to download the firmware 1.09.
I also read that there was several updates for the receiver including firmware for bug fix on HDMI and network
Please need help :)
Merry Christmas and many thanks!
Loren
Issue on upgrading Main/DSP Firmware on Onkyo TX-SR875
I tried to update Main Firmware of Onkyo TX-SR875 with USB to Serial Adapter via Windows 7 Desktop machine. As per given direction I did all like connecting properly USB to Serial Adapter with USB Cable, Select proper Com Port and Port Speed on App Updater, then Power on the AVR with holding Enter Button which gives me Main Firmware 1.01/07615L on display. But After clicking on update process Onkyo AVR shows "Searching F/W..." on display. No progress after that. So whats the problem with that? Am I missing something or done anything wrong?
I also facing issue when try to update DSP Firmware. DSP Firmware stucks in "DSP Updating....".
I would like to do it because my avr give lound popping on all DSP modes. Its works only in Pure Audio or Direct Audio mode. It has
1. DSP 1st: SR8051 08214A
2. DSP 2nd: SR8052 07518A
3. DSP 3rd: SR8053 07820B
HDMI: 1.01/07706A
Video: 07606E00924
Main: 87 1.07/08223A
HDMI 1.01/07706A
Does anyone happen to have the latest TX-SR876 files archived and willing to share?
I bought a near mint unit which will need the HDMI board caps swapped out and found it still has Main firmware 1.00 onboard.
Thanks in advance!
Thanks in advance!
HERE you go... US (and, presumably, Canada) DSP and Main Firmware for the 876. I'll leave the link up for a few days.
Note that, for the main firmware, both 1.04 and 1.05 are in the archive. As far as anybody knows (at least the last time I checked a few years ago), they are identical... it doesn't really matter which you use. I personally have 1.05 on my own 876. There is at least one main version higher than 1.05 (don't recall the specific version number), but it was for EU/PAL versions of the receiver and not applicable to US versions.
Thank you very much @jcalabria (as well as @rickardl behind the scenes :))
I needlessly fought with the DSP update today. I burned an Audio CD as per the instructions using Brasero and then tried playing the track from my PS3 Slim. No matter what settings I chose, the AVR would not take the update.
Long story short, I was only successful by playing the WAV file directly from a USB flash drive :cool:
I'll perform the 1.04 update a little later.
It if hasn't been discovered yet in this thread, the DHC99 and 876 Main FW .mot files are identical. Strange since the DHC99 and 906 both have Ethernet ports, I figured the larger size of the 906 firmware was due to additional Ethernet code.
HDMI: 1.01/07706A
Video: 07606E00924
HDMI 1.01/07706A
After successfully updated Firmware on Onkyo TX-SR875 I got above mentioned DSP 1, 2, & 3 with HDMI & Video Version. But 875 still having issues in Digital Sound. I swap another DSP Card and update its DSP Firmware but still same result, no sound and popping in digital sound.
During this process when I check firmware of both DSP Boards, I hit display button few times and I got weird data on Onkyo Screen. Can anybody throw some light on these?
Hi,
I'm looking for an update for an Onkyo TX-SR607. Nothing found on Onkyo website, maybe it's not possible to update it ?
I'm not a specialist in amp ant others audio things, but there are some of my issues:
- no voices for some DTS movies => obliged set stereo mode on input configuration (and don't retrieve the good conf...)
- make my Roku streaming stick crashing and desable the remote (works fine when plug on the TV)
Thanks for your help
Quote: Originally Posted by goksucats
I'm a little confused about the capacitor replacement issue on the TX-SR805. I have a silver Onkyo TX-SR805 made in Japan with a Serial Number 1790918222x I purchased in 12/07 from Amazon.com and have used happily for a year and a half with no problems. It appears mine is out of the range of the ones that need a new capacitor because it says "from 8276th" and mine is 8222. I don't know if it means ones under that or over that. And what exactly is the capacitor issue. I'm just nervous about sending my unit several states away to get service at A B L Corp in Michigan (I'm in KC). Is it something that needs to be done if I dont intend to own the 15 or so Blu-ray's authored early on that I've seen on the list? My understanding is DTS quickly changed their authoring techniques to solve the problem. And if mine does, indeed, need new capacitors, then what exactly does that entail, and what are the consequences if I don't do so? I have to confess, I don't even know exactly what we're talking about with the capacitors, what that means.
I might just call one of the local service centers up in Omaha, NE, to see if I can just run it by there in the morning some day, and see if they can do the firmware and dsp update for me. I don't think I can do any of teh updates, because the loader version seems to be 1.00.
The capacitor issue is when listening to DD+ or DTS-HD HR there may be noise or dropouts. If your unit doesn't have this problem you shouldn't worry about sending it in. Units "may" have this problem if the serial number is one that "may" be suspect, but if you don't hear a problem, no worries. HD discs for the most part used these audio codecs, blu-ray not so much if at all.
People with your loader have been circulating a jig to do firmware updates. Here is the thread for that info. I think one of the last few posts currently as the list, just add your name to it if you want to do the update. I believe along with the jig is the info./firmware etc that people need depending on your particular unit. If you have any questions about doing it go to that thread and post your questions. There are a lot of people who've done the update that way and who made the jigs, etc that can answer your questions.
http://www.avsforum.com/avs-vb/showt...mware&page=169
My Onkyo TX-SR875 has same issue in DD+ and other Digital Sound Format. It gives popping and Cracking or no sound in some channels in Digital input. Onkyo TX-SR805 and TX-SR875 is mostly same unit with same hardware except little changes in HDMI and all. So Which capacitor affect the DD+ or Digital Sound? I already tried DSP Firmware update but still not solve the issue. So I think may be any kind of poor capacitor or other electronics components create this issue.
Onkyo HDMI bin file request
I have had a bad HDMI flash on my TXsr805. I have since found out it was due to a substandard USB to RS232 converter. The Onkyo updater no longer works and cannot write the moto HDMI hex file. I was wondering whether anyone still has a copy of the HDMI bin file in case I want to try direct writing to the REON chip using the debug port?
I was originally posted in this thread by @ogoun
viz : rapidshare dot com /files/239261682/605HDMI-v1.02.bin.html
Edit : Nevermind. I built a jig and programmed the HDMI firmware directly using sp850es.exe. HDMI is back!
Integra DTC 9.8 firmware update
Hello,
I recently buy a refurbished Onkyo Integra DTC 9.8 US model and I was looking to upgrade his firmware.
when I access web control I get those info :
Welcome!
F/W version: Ver.1.00 / 07.06.02.A
Build date: Jun 04 2007 08:27:58
I heard there is sometimes 3 firmwares to update but no idea how to display what version each are.
Anyone willing to help me throu the process ? you'd be my "savior" :grin:
Regards.
M.N.
I just stumbled on this and found that I had some old Integra update materials in an archive from my old PCs.
I cannot help or support anyone with this but I would be happy to provide all I have to someone who could make them available to any can use them.
This is what I have:
That is very interesting, I could use them and even keep them avalable on a OneDrive link if you could send everything in a Zip file ?
I would be happy to send you the files but what I am hoping is that you would offer their availability to others through this site/thread.
Send me a PM with your email address and I will package them for you.
Backup...just in case.
You beat me to the punch Kal. Very nice of you to do this. If something fails, let me know as I have a folder with the updater app and updates as well.
BTW, I think you will still be interested to know, once again, that the 9.8 is still cranking out in my home theater. Still sounds great, but I'm finally thinking of getting a 4K projector with HDR, so I may let it go within the next year. What a work horse!
I have not had a use for these files in many years but, when I stumble on them, I always think that there must be people who would love to have them. I hate the idea that potentially useful information disappears.
Anecdote: I was looking for the appnotes for an electronic module that I have. After days of searching, I finally found that someone had posted it about 10-12 years ago. When I followed the link, I learned that it was I!!
Always nice to hear of happy experiences. Usually, complaints rise to the top.
