Status
Not open for further replies.
1 - 6 of 6 Posts
Just curious as to what people think about the sound quality of the OPPO for both regular cd's and dvd audio. More specifically, how does it compare with the pionneer 588?
sounds like 1's and 0's to me :)
Suggest you order one and give it a try for 30 days. I believe it to be a nice sounding player, but I'm running it to a Theta Casanova to do the processing. If you're concerned with its own audio DAC processing, I've no experience there. Contact extremephono.com to see what their current return policy might be. I'm sure there are other distributors as well.
the audio dacs on the oppo are respectable. the analog outs perform pretty well. i had a $80 sony dvd player that was just terrible on the analog audio side.
take in mind i have a dedicated setup to 2-ch, with a tube integrated and music hall cd-25 cd player
so i would say it's pretty good as long as you don't do any critical listening with it....
Sounds great with the HK7200 and Paradigms. I use a 25ft optical cable so I can shelf mount the Oppo close to the projector. Make use of a short DVI connection.
1 - 6 of 6 Posts
Status
