What is the relationship between throw distance(projector) and focus?
Can I use a pico projector with throw distance that less than minimum distance value?(in the projector's specs)
For example: Can I use a projector with this specs;
on 5" projector distance without any focusing problem?
If there will be a focusing problem, how can I handle this. With using some sort of optical system? Lenses?
*If question is off-topic please let me know and suggest another suitable platform in Stack Exchange community for me.
Code:
Projection Image Size (diagonal) 6 " ~ 60" (15.2 cm ~ 152.4 cm)
Projection Distance 7.9 " ~ 78.7" (20 cm ~ 200 cm)
