321 - 340 of 408 Posts
Discussion Starter #321
Discussion Starter #322
looking for opinions I know you all have them.
here is a look at the side and back wall I am making panels out of the same materiel as the back wall.
side wall
http://s629.photobucket.com/user/cw5billwade/media/1 theater/20131229_145142.jpg.html
back wall the door frame chair rail and crown will be black
http://s629.photobucket.com/user/cw5billwade/media/1 theater/20131229_215521.jpg.html
Should I finish them like Taner ridge frameless?
http://www.avsforum.com/t/739342/tanner-ridge-cinema-construction-thread/180#post_12175119
trim around the edge like beam and pole
http://www.avsforum.com/t/1464536/beam-and-pole-interruptus-not-bigmouthindc-and-nygiantsfan23-launch-the-rawlinsway-theater/450#post_23572934
frame on the surface like Esquire
http://www.avsforum.com/t/1289590/the-esquire-theater-construction-begins/1620#post_22558572
Question 2 if I do frame should it be black to match other trim or pait it red to match my coffers for a contrast since the fabric and wall colors are so close.
reminder of coffer colors
I like the look of the trim around the edge (beam and pole). Regardless of frame or trim, I would at least look at a contrasting color. Not sure there is a wrong answer here. Will just depend on which look you think looks best in your room.
I'm planning to trim around the sides of mine with a golden oak stain trim. Will give me the color combo I'm after, and add a nice bit of contrast to the room without being overpowering.
is the chair rail raised off the wall any or have backer board ? the reason i ask is if you did beam post to moldings being close to each other may look a little weird imo.
it maybe harder to do but i would almost think carfully removing the chair rail and base molding the doing like the ohio build that bigmouthindc did and applying the fabric to the fall then reinstalling the trim.. a lot of work but the theater is very nice and red between the columns witht he black trim would make the walls really pop.
Discussion Starter #330
I would like to announce a death in the family. My beloved 2002 mustang GT convertible after 100,000 miles needed some major work not to mention new tires. 18 months ago I had to rebuild the breaks at the tune of $3,000. Though I was willing to put the money in her my wife was not and wanted me to trade her in. I had custom paint and every bolt on mod short of a supercharger you can put on her. The suspension was rebuilt in 2009 and a new top in 2010. Wife was just tired of me "pouring money into it"
http://s629.photobucket.com/user/cw5billwade/media/mustang/DSC01460.jpg.html
http://s629.photobucket.com/user/cw5billwade/media/mustang/DSC01461.jpg.html http://s629.photobucket.com/user/cw5billwade/media/mustang/DSC01464.jpg.html
Here is the replacement a 2014 California Special
http://s629.photobucket.com/user/cw5billwade/media/mustang/2014/20140118_103517.jpg.html
http://s629.photobucket.com/user/cw5billwade/media/mustang/2014/20140118_103407.jpg.html http://s629.photobucket.com/user/cw5billwade/media/mustang/2014/20140118_103203.jpg.html
http://s629.photobucket.com/user/cw5billwade/media/mustang/2014/20140118_103433.jpg.html http://s629.photobucket.com/user/cw5billwade/media/mustang/2014/20140118_102720.jpg.html
My daughter bought a 2013 Mustang GT last year in "gotta have it Green"
Premium Member
That looks amazing Bill!
We had Rainbow when our little one was younger and while it wasn't cheap, we got our money's worth out of it.
I may have missed it, but did you do any sound proofing for your floor? I'm trying to determine what to do for my 2nd floor bonus room in that area.
Discussion Starter #338
Originally Posted by Maklar  /t/1468993/the-retirement-dream-home-theater/330#post_24275484
My build is above the garage I am not calling it a bonus room because I designed the house (along with builder and architect) for that area to be a theater. I lowered the roof of the workshop to accommodate the front of the theater to be 12” lower than the rear which is on level with the rest of the upstairs. In the first few pages of my thread you will see I used acoustical caulk in all of the cracks and holes between the garage and the theater. We also installed a second subfloor of ¾” Tung & Grove OSB using green glue and again every crack had acoustical caulk. The ceiling of the garage was spray foam and I had electrician put putty pads on the light fixtures and outlet for the openers. If there was living space down there I would have used R19 vise the spray foam and did a DW/GG/DW on the ceiling of that space with IB-1 clips.
caulk in garage
http://s629.photobucket.com/user/cw5billwade/media/theater/20130505_114806.jpg.html
you can see the caulk here
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_194452.jpg.html
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_194348.jpg.html
Here you can see the green glue on the 3/4" T&G and also the caulk on orginal sub floor and second sub floor going in.
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_132236.jpg.html
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_131840.jpg.html
we also put OSB on the 2x12 used to lower the work shop ceiling
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_115803.jpg.html
pile of T&G
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_115428.jpg.html
spray foam
http://s629.photobucket.com/user/cw5billwade/media/theater/20130511_115346.jpg.html
caulk on second sub floor
I did not take picture of putty pad in garage ceiling but here is one in the wall between theater and billiard room
Originally Posted by Maklar  /t/1468993/the-retirement-dream-home-theater/330#post_24275520
Going way back but do you know where this pic is from? My wife would like something like this for my theater so I'm hoping there is a build thread for it.
I will have to see if I can find it. It may have been in the show me your completed room thread and the person did not have his build linked in his name
Discussion Starter #339
here are some you can show her still looking for the other
http://www.avsforum.com/t/1061114/show-me-your-completed-theater/600#post_22463117
http://www.avsforum.com/t/1385501/jautors-rock-creek-theater-a-post-build-retrospective
