That is awesome, thank you!!!!!
I have been building out my 1600 sq ft basement over the last 4 yours and have finally focused attention on my modest theater room. I've read some of the MBM threads here and "chest thump" is an experience I want in my theater room. However, some here advise that to reach the lowest registers, one should add sealed subs to the mix.
1) In the current plan, the drivers are isolated from each in separate sections of the box. Is there a good reason to have them both in the same enclosed space instead?
2) The current tuning is 20hz. Are there good reasons for me to switch to the 31hz tuning? I know the port length would be reduced. Am I right that with the box up against the back of my couch, it would be more about the "chest thump" which is located above 40hz?
Yes, I see the practicality of building 2 separate boxes. So does 31hz tune make sense behind a couch, given the increased loudness? Or should I just commit to 4 VBSS units (2 in front) at 20hz tune? Here's my concept for a front VBSS - it's down-firing with the vent vertical at the rear. Should I consider front-facing instead because of my concrete floor? I'd have to give up on the "furniture" approach...1. Personally, I would build individual boxes, moving would be much easier.
2. 20hz tuning is effective if you have 3 or more VBSS, a single VBSS would not produce enough usable output at 20hz. 31 hz allow the sub to play louder vs 20 hz tuning.
Thanks for the compliments. Designing is one of the things I most enjoy doing. However, the design of course must follow function, and I'll admit my technical knowledge of speaker design is not what it should be to be confident in my design choices. I am a decent designer and woodworker, but I don't pretend to "grok" the mathematics of acoustics. The other factor nagging at me throughout this process of discovery is "guessing" at how the finished sub will actually sound, not to mention the amplification, speaker wiring, dsp and crossover magic that has to properly applied. So many variables! So I'm definitely one who will spend hours and hours on research until I'm pretty confident I'll get the outcome I expect.I tried to find it but could not, there is a video of a guy who made a VBSS coffee table and he has a cup of water on it and there are slight ripples, very minor. Walls in your room and pictures will rattle but the sub box, given bracing, doesn't flex much.
As Qguy said you want ports directed to you, ported will give you more bass you can feel over sealed, behind the couch or close is the way to go. My 4 are 8ft in front of me and they sound great and my couch trembles....I just want more couch trembling and lower volumes so hoping I can add 2 more right behind the couch!
Someone correct me if I am wrong but sealed 'should' play lower and have a quicker response but you will not feel the bass as much and it will not be as loud. Your slope wont have a peak in a sealed box like a ported box would and ported has way more output at the tune (given your room)
Your room will also be the biggest factor in how much bass you get at what frequency, spikes and nulls!
You box designs look amazing, can't wait to see your builds!
This one?I tried to find it but could not, there is a video of a guy who made a VBSS coffee table and he has a cup of water on it and there are slight ripples, very minor. Walls in your room and pictures will rattle but the sub box, given bracing, doesn't flex much.
Ha! Yes I watched all the videos on this build. Still, much less YouTube content on the VBSS than other subs. The Martys seen immensely popular...This one?
I know with these Matt got it down to a science so you need to keep internal volume within 10% so you can mess around with any box as long as the volume is the kept the same but port length and tuning I don't quite understand.Thanks for the compliments. Designing is one of the things I most enjoy doing. However, the design of course must follow function, and I'll admit my technical knowledge of speaker design is not what it should be to be confident in my design choices. I am a decent designer and woodworker, but I don't pretend to "grok" the mathematics of acoustics. The other factor nagging at me throughout this process of discovery is "guessing" at how the finished sub will actually sound, not to mention the amplification, speaker wiring, dsp and crossover magic that has to properly applied. So many variables! So I'm definitely one who will spend hours and hours on research until I'm pretty confident I'll get the outcome I expect.
Perhaps I need to join a local audiophile group so I can hear the different varieties of subs in an actual home use setting...
Those look great! Where in the room are you putting them?I just thought I would share my current and future VBSS builds
View attachment 3079553 View attachment 3079554 View attachment 3079555
