Status
Not open for further replies.
1 - 5 of 5 Posts
I hate to ask a dumb ?, but when watching football in digital(I still have not seen a game in hd), the yard lines seem to bend here and there, does everyone see this, or do I need a re alignment? On regular ch., be it cable or sat., in sd all lines appear straight. In hd/dig.ota, lines are bendy. Any thoughts or observations would be great.
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
Sounds like a hardware problem, this topic is moving to that forum.
"Better living thru modern, expensive electronics devices"
tm
You need to give us more information so that we can possibly assist you.
What kind of display/monitor are you using?
Where are your Brightness and contrast levels set? This question is specifically for your digital input or is it the same for your regular (cable) input?
Where is your sharpness level set?
Lee
[This message has been edited by LeeAntin (edited 09-02-2001).]
Discussion Starter · #4 ·
its a Sony 61"hs10, with jvc/dish 6000, cable & sat sd hooked up through replay, hd with rgb. Sometimes I notice a roll about 6" from the bottom of screen. Its like a distortion/bend that is not related)I dont think)to bends of straight lines on a football field. I guess I could post a pix?
Does sound like a geometry error. You need to get into the service menu and make sure the gonvergence grid is perfectly straight.
Vic Ruiz
STOP HDCP/DFAST/5C
1 - 5 of 5 Posts
Status
