361 - 380 of 388 Posts
Discussion Starter #361
So I demoed TIH last night at reference with the subs 12 dB hot(on test tones) 17-20 dB hot from 4.5-10 hz based on my response. The Cop car smash seen had a shutter effect throughout the theater and seats after the last punch right before he said is that all you got.
Best I’ve ever seen your theater look!
I second that MK! Its never looked so good! The flood was good news in disguise.
Discussion Starter #363
Thanks, everybody agrees who has been in it so far. It really is much darker in person than these iPhone pics. Putting the subs in the wall really created that much bigger effect which gave me the extra 3 feet for the back row to move off that wall. BTW, I had to go green so to speak and use soy glue pine and pillows in the acoustic panels. They seem to work pretty good, they actually stick out farther than what they would have been with batts. My 2 inch panels are more like 4 inches in the middle and my 4 inch panels are more like 6. The two supporting steel poles are wrapped in several layers of foam and then covered with black microsuede. My subs are also soy glue pine plywood and I used screws and pl premium on all the seams. I stuffed them with pillows which really make them sound solid. The riser is 13 inches tall.
Discussion Starter #364 (Edited)
That last graph was with a behringer NX3000, and then with a Peavy IPR2-7500. Notice the rolloff is much less.
I gained about 5-6 dB at 3 hz during those sweeps.
Discussion Starter #365
I meant there is about 5-6 dB less roll off at 3hz.
In my room 7 different people prefer the sound of these
over these
DIY JBL(best JBL design I owned)
which were preferred over these
BFM DR-250
JBL 3622
JTR triple 8
M&K S-5000THX
which started it all for me. That last picture were the M&K S-5000THX speakers that sound fantastic. There were quite a bit in between speakers as well. I have had the same people listen to my room for 12 years. My latest speaker with dual 12s, 9 Dual ring radiators(resonant frequency of 800hz or so, crossed at 1.6khz) sound the best to everybody. Clean, ultra detailed, huge sound stage, and non fatiguing. Some of the big horns I have had covered 500hz to 12khz easily and these are still preferred. I also had Fusion pure 10s, klipsch, other JBls, Sho-10s, Yorkvilles, behringers, axiom, magnepan, etc...
@MKtheater in your speaker rankings (post 206) Is that the "stock" tlah ranked highest of that group, or your ported line array?
Discussion Starter #367
It was the stock going from memory. I think we all preferred the smoother sound of the soft domes compared to the compression drivers tested. Of course these were all with subwoofers so we were not comparing speakers as stand alone solutions but integrated into my HT and just overall experience.
Geez MKT, you've had some AWESOME systems!
Discussion Starter #369 (Edited)
Thanks. Everytime a new design or something came out I tried it. I had horn subs before they became a thing around here. That is why when I see horn designs I don't try them because I like low end extension over excessive midbass which I have had both, for my room anyways.
Oh, I did not even put these in there which were better than the JBL 3622, and equivalent to the Yorkville unity 215.
Plus these
This last one was an fully horn loaded system, and those MBM were crazy.
Wow!
Discussion Starter #373
:eek: nice slope. i can go skiing on that bad boy.
Femi
People can understand why I don't port these anymore. They already act like a ported sub where I have them.
Discussion Starter #374
Here are a couple responses from speakers I have built. One is a 10 and the other is a 12.
10
12
and 45 degrees off axis in room.
My 12 in the wall rolls off like the 10 and they liked to be crossed over to 120hz to the subs. These are all sealed. The new 12 crosses over at 70-80hz.
Hey, did you make further changes to the speakers or more time in dialing them in? Did you end up adding more tweeters to the 10” version?
Discussion Starter #376
These are just single tweeter and single 10 and or 12. I am using capable drivers to play reference in room without compression.
Here they are
10
12
I am talking to myself LOL! Well here are some designs I have been working on and the TLAH is on the right.
Great work
Do you have a list of parts and speaker design plans? And the crossovers for each one. I’m sure it’s in this post somewhere, but I’m lazy. Lol.
Thanks and keep up the great work
Discussion Starter #378
I took all those apart. I made vertical towers and now bookshelves. Using higher quality and more powerful woofer and tweeters results in less work and a smoother response. Overall cost is about the same. My single 12 can play as loud but much lower than the dual 10s. My single horn loaded silk dome equals 2 of the other tweets and even more down low.
Pretty!
