1 - 4 of 4 Posts
Hi, I'm trying to find a decent subwoofer that has a thin footprint, as I don't have a lot of space to play with unfortunately. I'd like something by Energy/Def Tec/BIC etc., that has a similar footprint (I'd like to keep it to as less than 12" wide as I can) to this:
http://www.amazon.com/Yamaha-NS-SW21...064345&sr=1-90
I'm looking to spend $150-$200. Currently have Polk M60's and a CS1, however not looking for a Polk Sub.
Any suggestions are appreciated. Thanks in advance.
If I can't find something thin, I'm most likely going to get the BIC V1020, however I'd love to get something thinner.
http://www.amazon.com/BIC-V1020-Down.../dp/B0000Y2WY8
I've seen the HSU STF-1, which would probably fit my size requirements, but it's a little more than I want to spend.
Discussion Starter · #3 ·
Thanks for the response, but I'm not looking for a DIY solution. I'm sure there's nothing great out there in the 6" wide area, but I'm thinking more of the 9"-12" range.
1 - 4 of 4 Posts
