Hi there,
In my opinion, there are really only two top contenders in the $600 range for subwoofers at the moment. The Epik Knight and the MFW-15. The latter was just reviewed and tested by Craigsub.
It scored higher than a Velodyne DD-18 on both movies and music. It is about as close to an JL Fathom as you are likely to get. It is double the performance of an Epik Valor at 20 hz. The subwoofer is quite large and is ported. It looks very nice as well. For an additional $100, you can get a really nice finish too.
The Epik Knight hasn't been reviewed but it should be a stellar performer. Whether it will perform similarly or better than the MFW-15 remains to be seen. I'm not sure what finish options the Knight has so I guess you should email Chad for more info on that.
Cheers.
--Regards,
Cheers.
--Regards,
