Originally Posted by slicknick0013 /forum/post/20798821
Two vr1's with the VRC center channel speaker at $180. Haven't looked for the center speaker cheaper somewhere else. It's $414 totalled up. Is there a sub you recommend in the budget or would it be better to look for a better front channel setup at a great deal somewhere?
So far I've really only seen the 2 setups seriously recommended. If there are other serious contenders I'm not likely to replace the speakers i buy now for another 5+ yrs. So if there's a front channel setup i should wait to spend 800-1000 on I can wait a month.
You will definitely have more options with more money and waiting. If you are willing to wait until Christmas, you might find some great deals between Nov and Dec and get a superior speaker in that $1K range. The Boston, at that price, is really solid if you can't wait that long.
$1K gets you into a different level of speaker.
Subs are the same way. For $185 or so you can get a BIC F12 which would be vastly superior to the sub that you currently have. Personally, I would save up more for a sub and get one in the $380-450 range where you have more options. Once you hear a good quality sub, it really changes the dynamic of your whole system.
Are these speakers mostly for home theater?
