1 - 4 of 4 Posts
Discussion Starter #1
Hello
New to this forum and setting up A/V equip and only have a basic understanding of it all, if that. I use my MacBook pro to watch DVD's. It is hooked up to my Sony receiver and I have a HDTV and surround sound system. There is a buzz/humm/noise coming out of the speakers that sit on the fireplace mantle that also sit underneath the tv. The noise is only when I watch movies on the Mac. Not when I had cable or listen to the radio or ipod. Is there a thread about this? Can someone give me some advice? I am on my own on this one and not sure how to fix it. Thanks.
Beth
Discussion Starter #3
Also, the noise changes with the picture on the screen. When the picture is brighter or has more white in it, the noise is louder. When it is darker less noise.
I can hear a bit of noise when using my headphones to listen to movies/music on my MBP. I can only hear it when there is nothing playing (eg between scenes or songs). I wonder if you have a similar issue that is getting amplified through your receiver?
1 - 4 of 4 Posts
