Status
Not open for further replies.
1 - 6 of 6 Posts
Hello,
Anyone have a throw distance calculator for 16:9 aspect for the Sony 12HT or the NEC HT1000?
Am trying to keep a ceiling mounted pj 15-17ft from my screen which is about 96" diagonal.
Using http://projectorcatalog.com I get the following results:
Sony 12 HT:
Diagonal size range: 116.2" to 158.3".
Throw ratio estimated using focal length and panel size.
NEC HT1000:
Diagonal size range: 109.8" to 152.7".
So it seems you may have to use a larger screen, or move the projector closer, or possibly use a long throw lense.
Jonas
Discussion Starter · #4 ·
Any ideas what the H56 throw is (or any other comparable in terms of quality of image digital??)......... I'm quite limited with quality vs price vs my required throw........
1 - 6 of 6 Posts
Status
