Status
Not open for further replies.
1 - 5 of 5 Posts
· Registered
Whenever I try to sechedule a recording via TitanTV, it crashes my HiPix. It will try to start recording, the signal will drop to zero, and a dialog box pops up telling me to check my antenna connection. If I manually schedule a recording, it works just fine. What the heck is going on?
I am running HiPix 3.5.2 on WinXP Pro. This problem is driving me nuts.
I didn't have this problem before TitanTV changed to their new format. How could that be causing it? Is it somehow telling my HiPix to change antenna inputs?
:confused:
BTW, I just built this HTPC a few days ago. It is an Athlon XP 1800 with 768MB of DDR RAM and 160GB of storage. I have all of the windows updates, and I have installed all of the new drivers and patches on Midwinter's site.
Ben
· Registered
Use the cleaner and re-install. Takes 5 minutes.
Joe
1 - 5 of 5 Posts
Status
