Status
Not open for further replies.
1 - 2 of 2 Posts
Banned
I have 5-DirecTV/Tivo's in 4 rooms and have just installed the house distribution system from www.avcast.com and am having a problem with the remote control codes randomly changing in the TiVo.
AVCast, BTW, allows any TiVo to be viewed in any room via RF modulation and the hard wiring of the existing cable TV system.
1. Each Tivo has it's own remote control code i.e. 1 through 5.
2. The units are wired correctly.
3. The AVCast sensor is turned around when progamming the code.
Has anyone else seen the TiVo remote control codes randomly change?
I am guessing that your DirecTiVos must be Philips or Hughes because I don't think there are 5 unique codes for the Sony's.
With Sony's, there is a situation where the remote codes can be changed unintentionally. With any Sony DirecTiVo, if you are in the system information menu, any remote with any code will operate the DirecTiVo that is in System Information. And, the last remote used will cause the DirecTiVo to be reset to that remote code.
Perhaps something similar is happening with your DirecTiVo units.
1 - 2 of 2 Posts
Status
