1 - 3 of 3 Posts
I'm strictly an over-the-air viewer with antenna on the roof and considering the Tivo Roamio base model that allows antenna connection. However, I want to be sure that the program guide Tivo provides antenna viewers is sufficiently sophisticated, including the ability to do name based recordings, scheduling non-repeats, etc. Do they do their own or do they use Rovi or some other service. Thanks.
Yes, you get everything using TiVo as OTA the same as the cable users. The guide is from Tribune Media and has all the meta data you could want. So name-based recording, season passes, wishlists, repeat handling, conflict handling, etc. are all part of the TiVo recording service whether using cable or OTA.
I'm OTA and have been using TiVo for over 5 yr -- only a HTPC running DVR software comes close.
1 - 3 of 3 Posts
