Status
Not open for further replies.
1 - 1 of 1 Posts
Hello all,
I'm using DVArchive and a linksys 5 port switch to DL shows I've saved
on my 5040 to my PC. I noticed sometimes I could only DL shows
at speeds of around 275-350, very slow. It took about 2 hours
for a medium quality 2hr movie to finish. I did however receive shows
at 580-600, cutting the time in half! Believe it or not, turning off the
PVR fixed the problem. I've tested it, slows down when on, not when
off.
I want to make the shows I've DL into SVCDs.
I use DVD2AVI to save project, and load the d2v file into Tmpgenc.
(Thanks to others on this forum for this method!!!!!)
This is where things had been going wrong, when I loaded the
mpa file...BLAM crash!!! Tmpg gets some type of memory error.
The way around this is to get winamp, and a simple wav write
plugin. convert the mpa into wav and load into Tmpg.
No more crashing at all.
Go to source...bla bla Time offset, you know the drill.
1 - 1 of 1 Posts
Status
