I am running a Samsung 1080p DLP powered with 780G for my GPU. The two options I have as I see it are to fix the overscan with ATI CCC and lower the resolution to 1820x1024 to best fit within my bezel or to leave it at 1920x1080. My questions is when playing a Blu Ray will I be losing any detail if running at the lower resolution? Is it then trying to scale the Blu Ray that is 1080p down to 1820x1024 or is it cropping it in some way so that I retain the 1:1 pixel mapping?
Or is this a moot point for some other reason that I am not understanding?
This HTPC is only used for audio/video and the desktop is never seen except when tweaking. The one problem I would have is if it would be better to run at a full 1080p then the GUI for TMT3 then runs into the bezel and I don't see any way to adjust for it. I can adjust the GUI for 7MC by choosing either LCD.
