More zoom = brighter picture and less contrast. Less zoom = less bright and more contrast. It depends on what you need. The HD1000U has plenty of light output for a dark room at that size, so minimum zoom or somewhere in between would probably be best for contrast.
The difference between minmum and maximum contrast may or may not be a noticeable difference to you. The only way for you to really tell is to try the same screen size with both maximum zoom and minmum zoom displaying the same images.
