1 - 3 of 3 Posts
I have a Sony KDS-50A2000 and have experiencing the green tint issue. I thought it was the lamp, but replacing it didn't help. After searching online, I found that this is the fairly common issue and there was apparently a class action lawsuit to get these sets fixed/replaced.
Is it too late to expect Sony to do anything to fix this problem for me, or am I a little late to the party? I'd really hate to have to pay a crazy amount to get this fixed.
It's worth a shot. You may get a free OB repair or a slightly discounted replacement TV. Otherwise, according to the lawsuit, you are still at least entitled to $200, I think, unless you opted out. Your TV is around 7 years old now and well outside of the warranty and extended warranty periods.
If sony won't give you anything, I highly discourage you from paying $1000 to get it repaired when a new TV will cost far less and perform much better. Even if you perform the repair yourself, you're looking at $300 or so for parts. Then the repair will probably only last a few years. Also consider that a new TV won't require a $100 bulb every few years. So you should factor that into your cost analysis as well. That can amount to $500 or more over the life of the TV.
Discussion Starter · #3 ·
Originally Posted by mdavej  /t/1463098/too-late-to-have-sony-fix-green-hue-issue-on-kds-50a2000#post_23099209
It turns out that the lawsuit was only valid for the US and doesn't apply to Canada.
Regardless, Sony did provide me with a Sony Store credit to use towards a new TV. Now I'm trying to decide if I wait for the new W series sets or get the current 55" HX850.
1 - 3 of 3 Posts
