1 - 8 of 8 Posts
Hey guys, need an understanding on this. I have a Belkin PF60 power center that I was going to use to send power to all of my gear but now I'm not sure. Below is the equipment list and their amperage draw...
Marantz SR5005 - 650 watts or 5.4 amps
Behringer EP4000 - 9.6 amps
Panasonic Bluray Player - 9.9 watts or .08 amps
Behringer Feedback Destroyer - 200 mA
Panasonic 4000 projector - 3 amps
The Belkin has a built in 15A Breaker on it but with 13 outputs, it just doesn't make sense. If it's as cut and dry as it looks, will I already be overloading it with the current gear?
It would probably be OK since it is very unlikely you will ever draw peak power, but I would plug the power amp straight into the outlet and not into the conditioner.
BTW, it is likely your wall outlet has a 15A breaker on it...
Discussion Starter · #3 ·
So I am looking at this correctly though? That was my next though too, use a separate circuit for the Behringer amp since that will put out the largest load.
Audio power amps do not need power conditioners. They most typically have simple unregulated 60hz based power supplies which if engineered properly (which is quite easy to do) are virtually indestructible by routine power spikes.
Now where you can get in a quandry is a high power AV receiver with digital processors inside.
Discussion Starter · #6 ·
Great, thanks for the info! I will then put my power hungry amp on it's own circuit and the rest on the power console
Slightly off topic, but does your PF60 say PureAV on the front left or Belken. Mine says Belken but all the images on the web show PureAV.
Wondering if mine is somehow different.
1 - 8 of 8 Posts
