Originally Posted by Chicagorep /forum/post/18163976
Current is like amperage in electricity. You need amperage to make things happen. Static electricity is about 30,000 volts but the amperage is so tiny it's harmless. Wattage is the voltage and current is the amperage.
High current amps like Halo, Krell, Classe' and other can peak at 45 amps of current. Watts are cheap to produce.
Wattage is the
product of voltage and current:
P = E * I (Watt's law)
You never have too much current, because high current won't be supplied to your speakers unless they draw it, that is, unless they present a low-impedance load to the amplifier. That's Ohm's law (transposed for current):
I = E/R. If "R" (resistance) is low, then "I" (current draw) will be high (to the extent that the output device can supply it). Keep in mind, though, that speaker impedance varies with frequency, and speakers' impedance ratings (typically 8 ohms) are nominal values. Some speakers can hit dangerously low impedances at certain frequencies, but few actually do.
The original question was whether his receiver's amp has too much power for his speakers, and the answer is
no. Too much available power is almost never a problem, as driving an amp into clipping (resulting in wave compression and, ironically, excessive average power levels) is what's most likely to damage speakers. A big amp is less likely to clip. It's possible to overdrive speakers with gobs of clean power, but, as modern ported speakers have sensitivity ratings around 90 dB or so (typically much higher for horn-drivin units like Klipsch), it'd probably be insanely loud.
Finally, remember this: The vast majority of listening occurs at one or two watts. So relax.
