Status
Not open for further replies.
1 - 3 of 3 Posts
I am cery close to making a purchase of an HS10-It has everything I need in a PJ but I am concerned about the installation.
The top of my 16 x 9 screen is only 1 inch down from the ceiling, and I am going to be flush mounting the PJ to the ceiling. Even flush mounted though, I'm guessing the bottom of the lens (closest part to ceiling) will be at least 3 inches from the ceiling. I can vertically keystone I am sure, but will this drastically affect the image? Should I consider a Z1 (with lens shift) because of this?
I think some of the flush mounts (like Chief or Peerless) will still allow you to tilt the projector up and down a bit. And 3" of tilt over a throw distance of 12' or so shouldn't cause any need for keystone adjustment- it's less than 2 degrees.
Discussion Starter · #3 ·
thank you. If that's the case I am getting really excited. I know the sony is the one I want, and I was afraid I was going to have to switch due to that one issue. Again, thank you for the input.
1 - 3 of 3 Posts
Status
