Status
Not open for further replies.
1 - 2 of 2 Posts
I'm building a torus screen. Currently I have the box nearly complete and the screen material should arrive next week.
Can someone here recommend an appropriate fan size/configuration? A friend suggested specs of "1/2 inch or broader static pressure", but the specs I'm looking at do not mention static pressure values.
The box is 120" by 64", and I'm using Vutec PearlBright screen material (3.1 gain).
One other question - has anyone tried Vutec's newest screen material called "Silverstar". It's available in gains from 4.5 to 9.5. I am assuming it's a silver screen, and since I use a CRT, I'm not sure it would have been the best choice for me. Still, I was wondering how this material would have worked for a torus given it's high gain properties.
Any help would be most appreciated
Tim Williams
The Silverstar would work very poorly for a Torus as it is not flexible. It's rigid.
1 - 2 of 2 Posts
Status
