Status
Not open for further replies.
1 - 1 of 1 Posts
I was wondering if anyone with a Tosh DST3K has noticed a pixilation problem related to the heat of the unit?
Quick background- I was having problems with certain channels, especially SHOHD (Ch.543), HBO West, Speed Channel and bunch of others that would pixelate and pause. I tweaked the dish as best as I could but could still had problems with the picture. But I have 2 other non-HD receivers where the picture was fine (except SHOHD, couldn’t check it), so I didn’t think it was the signal. When I looked at signal of the problematic channels, they would jump in signal strength, going up and down. Thought it was the diplexer, cable, etc. I then put a fan on the STB and once it had cooled enough, I got all the channels with perfect pictures. Checking the signal strength showed that it was stable now. So I’m assuming that there is a problem internally with my Tosh, is that right? How long was the turnaround for people who turned in their boxes to get them back?
1 - 1 of 1 Posts
Status
