Status
Not open for further replies.
1 - 3 of 3 Posts
I have a Toshiba 57H81 that is about 8 months old. The problem I'm having is that occasionally these horizontal lines will pop up for a second or so, then go away. They're normally a green or bluish color. I've seen it happen on several different inputs (Progressive DVD, Satellite, VCR, Antenna). It seems to happen randomly. If I watch TV for a couple of hours it will probably happen a couple of times. Some nights it might not happen at all, other nights it will happen several times. The lines do not cover the entire screen from top to bottom either, maybe a foot tall, usually closer to the upper portion of the screen, but not always. Another thing that happens (not sure if the two are related), is it will make a loud pop sound, and turn off. Then it comes back on and everything is fine. This issue does not happen all that often (5 times since I've owned it). A local TV repair shop has it in their shop now. Before taking it away they thought it might be dropping scan lines (they did not see it happen, they were just saying this based on my description of the problem), but since they've had it in their shop the past week, they cannot reproduce the problem. Does anyone have an idea of what the problem might be? It's still under Toshiba Warranty, but what do I do if the repair shop can't find the problem. Thanks for any help.
Welcome to the forums. The shutdown and popping sound might be high-voltage arcing, with the protection circuit kicking in. Also, I get similar random on-screen visual glitches at about the same long-term rate you describe. Mine, on a Philips RPTV, are a brief loss of one color or picture sync. A Philips specialist thought it might be momentary overloading of the set's microprocessor. I just ignore it (21 months), hoping at each 2-3-second glitch it'll continue resetting to normal. -- John
Discussion Starter · #3 ·
Thanks for sharing. I hope my problem is something that can be resolved. It can be pretty annoying when watching a movie on DVD and the lines pop up occasionally to distract me.
1 - 3 of 3 Posts
Status
