Status
Not open for further replies.
1 - 3 of 3 Posts
Will I be able to watch sd channels upconverted through the 1080i hd outputs, or is it necessary to switch the receiver to sd and use the s-video connection? I would prefer to watch all through the hd component cable connection.
Oh, I assume that the
Toshiba 3000 had component cable outputs. Is this correct? Does it also have vga output? Just curious about the latter.
Is there a fan and is it loud? Is it on all the time like the Sony even when the unit is not on?
Thanks to all.
Yes you will, no need to switch! Component out YES! No VGA! NO FAN!
Meredith (KPHO) SUCKs! Phoenix CBS station with no HD just SD.
1 - 3 of 3 Posts
Status
