21 - 23 of 23 Posts
Discussion Starter #21
Thanks for the answer.
I wonder what satellite systems in Canada the RD-XS35's TVGOS works with.
Originally Posted by nextoo /forum/post/14264352
The XS35/55 added satellite ir blaster support. Meaning here in the states it incorporated Direct and Dish ir STB codes.
This requires you to use the L-3 input for the satellite video input. When you set up a timer recording using the ir blaster to control a satellite STB the input always defaults to L-3.
I knew you would know.
The instruction in the XS35 users manual on how to set timer recordings are wrong (1/3 of the necessary presses are not mentioned), and the last step in the process (daily/weekly) is not even mentioned.
Here's what works on my XS35:
1) Press TV GUIDE.
TV Guide On Screen LISTINGS appears.
1A) Press MENU
Watch Now appears
1B) Press UP
'Go to Service Bar' appears
1C) Press SELECT
service bar becomes active
2A) Press LEFT twice to SCHEDULE.
3) Press Menu.
"Schedule Options" appears.
4) Press Up/Down to select "new manual recording" then press ENTER.
"Record Options" appears.
5) Press Up/Down to select "date" then press the number buttons to input
To shift the highlight, press Up/Down.
6) Press Up/Down to select "start" then press the number buttons or Left/Right for am/pm).
Also set "end" in the same manner.
7) Press Up/Down to select "channel" then press the number buttons
8) Press Up/Down to select "input" then press Left/Right to select the input.
Tuner: TV broadcast, Line 1, 2, 3: external device connected to the recorder
9) Press Up/Down to select "recorder" then press Left/Right to select the recording device
9A) Press UP/Down to select 'frequency' then press Left/Right to select Daily/Weekly/Off
10)Press ENTER.
"Record Options" is closed.
The icon appears on the TV program.
Anyone who plans to do manual recording with an XS35 (and probably XS55 as well) should buy a universal remote with the ability to do macros and replace the 9-step sequence to get to the timer screen with a single button.
21 - 23 of 23 Posts
