1 - 6 of 6 Posts
· Registered
Originally Posted by doug877 /forum/post/16853044
I called Toshiba and they said my burner is bad. How can I replace this and what type of burner will work?
thanks, Doug
It's buried in the RD-XS32 replacement burner thread, as well as answers to what aftermarket burners work with which model.
Not surprisingly, another RD-XS35 burner bites the dust! That model has single-handedly given Toshiba RD-XS units a bad rap for burners. Unfortunately, the burner in the RD-XS35 is proprietary and cannot be replaced with an aftermarket burner (the RD-XS55 uses the same burner).
The same holds true for the RD-XS52 and RD-KX50, although both use a different proprietary burner than the RD-XS35.
You can replace the burners yourself on the RD-XS32/34/54, but there is often some loss of functionality.
· Registered
I think the XS32's burner (which could barely produce a compliant DVD in terms of PI/PO errors even when brand new-- and I had 2 units to test) which tends to blow up fairly reliably as well set up the XS' reputation for having crappy burners long before the 35 was a glimmer in Toshiba's eye.
It's really too bad they made the most feature rich models on the market but crippled them with absolutely terrible DVD burners.
· Registered
As much as I'm astounded to hear myself saying this about a consumer electronics product, that isn't a bad price at all when just the part can't be found unless you pay considerably more.
https://www.ued.net/ued/addItems.do?...=TSHP000459010
http://www.partstore.com/Part/Toshib....aspx?s=google
http://tigerdirect.partsearch.com/Pa...umber=RDXS35SU
http://www.encompassparts.com/products/?P000459010
Mine's been going fine since I got it fixed in 2007. Grudgingly, that's not bad to have a functional RD-XS35, arguably what some consider one of the best DVD recorders ever made or that will ever be made for the North American market.
1 - 6 of 6 Posts
