Does anyone know how to remove the zoom icon on the old model toshiba sd 5109? Thanks
D dholmes54 · Registered Joined Aug 19, 2002 · 1,871 Posts Discussion Starter · #1 · Dec 2, 2002 Only show this user Does anyone know how to remove the zoom icon on the old model toshiba sd 5109? Thanks
H hob · Banned Joined Jul 20, 2001 · 3,403 Posts #2 · Dec 2, 2002 Only show this user On my Toshiba 2002 SD-4800 you would zoom it where you want it then hit you down arrow, then push the round center key; it will fade altogether.
B backset · Registered Joined Mar 13, 2002 · 111 Posts #3 · Dec 4, 2002 Only show this user As far as I could tell there was no way to get rid of the words "Zoom 1" or "Zoom 2"...etc on the 5109. Most annoying thing....ever.
