that's cool. wonder what min spec reqs are for good performance.
Originally Posted by eapleitez /forum/post/0
Are you sure you need at least a 6800Ultra and a X2 3800+ CPU to play back HD DVD? That's some heavy duty hardware, and would seem to me to be more powerful than an A1 or A2.
Originally Posted by MidnightWatcher /forum/post/0
I could be wrong, Cyblerlink recommends a 6600GT minimum, no mention of the 6800 (even though it is supposedly faster).
Originally Posted by my94r/t /forum/post/0
I'm not sure if there is a 6800 series card that is HDCP compliant(or atleast at the time that was written), so that could be why its not mentioned.
It is indeed a faster, more powerful series of cards.
I would recommend going with a 7-series card such as the 7600GT at a minimum.
You don't need an HDCP compliant card since you can use VGA or component. You only need HDCP if you want to connect via DVI or HDMI. If I remember correctly the 6800 originally had an issue with WMV-HD hardware acceleration when it first came out.
Originally Posted by chlngr1970 /forum/post/0
So, I am wondering if my laptop would do this...
- A64 4000+
- ATI X600 PCIX 128MB
- 1G DDR 2700
- HDDVD Drive ( USB Toshiba, or XBox HDAO )
I haven't bought the drive yet, I was planing on getting the HDAO for my HTPC, but thought this would be fun to add to my laptop, if I could.
Unfortunately, I can only upgrade my memory 512, by taking out one of my 512 sticks and putting in a 1G stick, for a total of 1.5G. Vista runs good on it, with a Performance Rating of a 2.0 ( Video card IIRC )
Any idea if this will work?
j
