1 - 5 of 5 Posts
· Registered
I'm in the process of "in-walling" my home theatre installation and part of that entails moving most of the equipment to a remote wiring closet. One of my objectives was to have a console rack available in the HT living space and then make all the connections from a remote switcher there to the main AV remote rack.
The bit that has me concerned and has prompted this thread is a lack of information on the reliable operating temperatures for Toslink optical cables. To accomplish this install, my cable runs will have to make a short (3m ~10ft) run through the unfinished attic space. Since I live in Florida, temperatures can get pretty hot up there. Since Toslink is essentially a plastic/quartz fibre, I have concerns over long-term reliability.
Various other cable manufacturers have quoted operating temperature ranges from -20'C to 85'C (which is about 185'F). I'm pretty sure the attic doesn't get THAT hot, but it might get in the 150'F range.
Any input would be welcome! I'll have pictures and a dedicated project thread coming soon.
· Registered
If you get cable rated to 85'C, then you should be okay.
· Registered
Discussion Starter · #5 ·
Just as an FYI, I contact Monoprice technical support and they indicated that none of their Toslink product lines are CL2 rated and they do not have temperature ratings available.
1 - 5 of 5 Posts
