1 - 12 of 12 Posts
shhh...
Discussion Starter · #2 ·
I put a quick video up showing our Remote Edition on Android here http://www.youtube.com/watch?v=yIG9x5SAr3w
Pretty much going to be the same as our iphone/itouch/ipad IR remote here
http://totalcontrolapp.com/index.php...=108&Itemid=92
It won't have the security functions and profiles in the initial release though. Other than that it will have the main IR functionality such as IR dbase support, learn IR functionality, macro support, prebuilt GUI for device types, etc. So basically you can set this all up in less than 1/2 hour for many setups.
It will be missing punch through support in the initial version but you can override buttons with learned IR so you can basically punch through manually for now until we add it in.
On the hardware side it will support the bitwisecontrols BC4 and HAI HTX Home Theater Extender
Should be released within the month i believe directly via our website.
Does it have a programming feature?
Ie: Press "Go"
Receiver, projector and Blu-ray player all power up. Loaded disk plays.
Discussion Starter · #5 ·
we support macros or 'programming' via the Bitwise Project Editor. You basically make the macro on there and upload it to the hardware unit. Then we call the macro in the app as shown in the video. So the short answer is yes it has a programming feature but the long answer is the 'programming' part is done with Bitwise's software not ours and uploaded to the Bitwise Hardware component and we call the 'programming' from there.
As I just upgraded my phone 2 weeks ago to an Android OS based phone I may want to look into this as well. Not as programming saavy as others here but the app has piqued my interest.
Discussion Starter · #8 ·
Getting closer...added a new video showcasing the setup UI and functionality such as user profiles, support for multiple hardware units, categories/subcategories (i.e. home vs, vacation home, living room vs. bedroom, etc.), device listings, favorites section as well as how quick it is to add a device into the app based on the built in IR dbase.
Youtube video here YouTube - Total Control Android Remote Setup
http://www.youtube.com/watch?v=6JEAHg8pLyw
finishing up the learning feature functionality and we will release at that point. shouldn't take long on that part.
i' m very interrseting for android version,
the software it's not ready ?
for the hardware HAI HTX Home Theater it's very expensive
the bitwisecontrols BC4 what the price ? where find a dealer ?
the software not control this hardware ? // www.smarthome...IP-to-IR/p.aspx
excuse my english, i' m french.....
1 - 12 of 12 Posts
