1 - 3 of 3 Posts
· Registered
Greetings,
I'm looking into transducers (and amp) for my couch currently and I'm trying to find most impact for my dollar so to speak.
My couch is relatively new and I'd like to avoid modifying it directly for the time being. I'm open to any suggestion for manufactures. I've seen a buttkicker system where you mount it onto a platform and set the couch on it, but I wasn't sure if other companies have similar options or not.
Also, I'd like to spend under $400 for the transducers and amps. $400 is the absolute max obviously, but under would be really appreciated.
Thanks for looking
· Registered
the only one i'm aware of is the buttkicker lfe kit....
clicky ...
not sure what they go for these days, but i can tell you that it works... i don't have mine anymore, though...
there may be others...
1 - 3 of 3 Posts
