1 - 3 of 3 Posts
My parents drove to the States from Canada to pick up a 65" Plasma and some other goods.
None of us knew at the time of their departure that Plasma's should not be laid horizontally flat.
The TV in question is a 65" Panasonic VT60 with the following dimensions:
Dimensions (H x W x D) - with stand 38.4" x 60.3" x 12.8"
Dimensions (H x W x D) - without stand 35" x 60.3" x 2"
Dimensions (H x W x D) - Shipping 40.5" x 75.8" x 14.1"
Weight - Shipping 136.7 lbs.
Here are the car dimensions in mm:
If you look at the diagram, it is 850mm / 33.6" from floorboard to head-liner. So, not enough room to place vertically [needs 35" - outside of box].
There is no tow-hook on the car, so they won't be able to rent a trailer.
So, the available options [that I can see] are :
-Take the risk and lay it horizontally
-Lay it diagonally
-Rent a cargo van
-Drive back with their pick-up truck several months from now when they return for more business *probably the most likely to occur option, but it would be nice to grab it while they are there.
The trip home will take 13 hours - from Utah to Alberta
Any other options/choices you can think of?
What would you do? Just pick it up several months down the line when a truck is available?
Thanks for the help,
-Quickstrike
I don't think I would have it sitting horizontally or diagonally in a car over such a long distance. Any bump would cause bending and bowing of the tv and I would worry about the glass breaking or cracking. I would wait until you can get a bigger vehicle to stand it vertically in it's box. Plus you wouldn't put your parents through the stress of worrying about the tv for 1100 miles.
1 - 3 of 3 Posts
