1 - 5 of 5 Posts
I need to transport a brand new Samsung 32" LED TV 750 miles and I am in a bind because it can only fit in my car laying flat in the trunk OR upright on the backseat but on its end not its side.  If that is not clear I mean it will have to sit on the seat on its smaller dimension (approximately 20") with its longer dimension (approximately 36") up against the back of the seat/headrest.
These are my only options.  I will be travelling with someone sitting in the backseat so the TV cannot fit across the seat...
If you had to do it what would be your pick!
The unit is brand new in its original box with all foam, protective packaging, etc.
THANKS
chris
I moved several over the last couple of years including a 55" plasma. All vertical.
But that small LCD should be fine on its back.
1 - 5 of 5 Posts
