I see no problem with what you're proposing. The speakers work well together, and they'll work well in that room with that receiver at moderate playback levels. If and when you upgrade the receiver, the speakers will then be up to the task, so it's also a good investment.
Make sure you ask your dealer about the custom paint matching option. It sounds like you'll have five inwall grills, and they'd look very custom if they were the exact color of the walls.
Thanks for considering Triad.
