I've used the 'higher crossover trick' a few times and it can really help out a system that is struggling in terms of power and speaker output, without investing a dime, since so many folks are running subs way below capacity and many of the subs in the $500 to 1k range (which I would assume is where budget systems end up, and a budget system is one where the speakers may not be quite up to the task) have good response to 150hz or higher....
But yes, buying a higher output speaker would be the preferred method, if it is an option. But it is amazing what using a 100 or 120hz crossover can do in terms of making a modest system sound far more solid that it might with 80hz crossovers. It is not without some compromises, of course, but on balance it can help when the alternative to get more powerful speakers is not an option.
That said, I agree that having more headroom in the speakers (and the amplification to make use of it) does offer lots of great opportunities to get that crossover region working smoothly, without worry about whether the best crossover is 60hz or 120hz or whatever. Were I to design my room over again, I would have gone with Silver LCR instead of Bronze LCR just to have that flexibility.
