1 - 9 of 9 Posts
My McIntosh pre-amp (C46) does not seem to want to trigger my 12 volt SMS-1 on or off.
Are there any devices that can help this problem besides Mano-a-Mano.
Hello
Try another 12 volt source, and measure the preamp trigger out with a voltmeter. Make sure your connections are solid.
Discussion Starter · #3 ·
Originally Posted by Tim in Phoenix /forum/post/16983370
Hello
I think my McIntosh is 5 volts not 12volts. Is there any electronic devices that can boost volts between gear for trigger function.
(I will try the trigger on another device. Thanks!)
Discussion Starter · #5 ·
Originally Posted by Don O'Brien /forum/post/16985131
Do you have 5v coming out of the C46?
The company said yes. 5v for MAC trigger
SMS-1 needs 12v, so I guess I push a button.
This may work, however the output @ 12v is 800ma which may be too much. Your local alarm store, like alarm warehouse or adi should be able to give you a relay that activates @ 5v w/ a transformer to step up to 12v output.
There was an old Sony lcd projector that had a 5v output and there was a device that upconverted the voltage. Forgive my prior email, I was just trying to make sure that you measured 5v with a multimeter before trying to suggest a solution.
If you have a macro based 3rd party remote, you could stick the "on" command for the SMS into the Power On sequence for the c46.
sorry just took a closer look at that link, makes it alot more complicated than it needs to be. you basically need an ac to dc converter (wall wart) that has an output of 12v at what ever amperage you need ex. 200ma
now you need a relay that will close an independent circuit with a 5v input.
Should be like $10 worth of parts at your local alarm supply and they will be able to show you how to wire it
Discussion Starter · #9 ·
1 - 9 of 9 Posts
